Tilers Forums Bottom wall tile advice - Tilers Forums
Hi, Ive had a low shower tray installed, 27mm height & will be tiling using metro tiles that are 100mm. I also plan to use lvt flooring 6mm thickness.
Would you start with a full tile around shower tray & have narrow off cuts of tiles at the floor or could you suggest a better option?
To Continue reading Bottom wall tile advice...
Feed automatically fed from the UK Tiling Forum[url] at [url=https://www.tilersforums.com/forums/uk-tiling-forum/]UK | Tilers Forums.
