BAL With BAL Micromax Grout-Effect Sealant, you're installing with a smooth, matt-sealant that is really easy to tool!
Ardex owned BAL brand
For movement joints or most applications, use in 6mm x 6mm cross sections. Once applied, the surface of the sealant should be tooled within 15 minutes of application.
To smooth down the silicone, use a wet silicone tool/spatula or similar. Recommended tools should be plastic or wood materials – metal tools should be avoided for best results.
Top Tip: Avoid repeated smoothing down of the surface, as this can reduce the matt-effect.
#GroutEffect #SealantApplication #HomeImprovement #SiliconeSealant #ToolingTips #ConstructionTips #tiling #tiles
(Feed generated with FetchRSS)
Continue reading...
This is an automated post from BAL Tiling on facebook, to Tilers Talk
